Activity Forums AJA Video Systems Downconvert 720p 23.976 issue
  • Downconvert 720p 23.976 issue
    Posted by Matt Bishop on May 22, 2007 at 3:11 pm
    Hello there I am trying to downconvert 720p 23.976 8bit uncompressed to SD 29.97 using a KonaLHE and the output on my DBeta is running longer then the sequence in my timeline.
    Has anyone successfully output 720p 23.976 to a stand definition tape and were they able to keep the timcode exactly the same.
    Any thoughts or work around would be greatly appreciated. I have been altering my edits to make it work, but there must be a solution to keep the timecode the same from the timeline to the tape.
    I am using FCP 5.14 and the latest Kona drivers.
    Many thanks
    Matt
    Gary Adcock replied 19 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Gary Adcock
    May 22, 2007 at 5:37 pm
    [Matt] “Has anyone successfully output 720p 23.976 to a stand definition tape and were they able to keep the timcode exactly the same.”
    No
    because you cannot, 24p is always non drop and your SD master is going to be drop frame I imagine.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Matt Bishop
    May 22, 2007 at 6:24 pm
    So if this isn’t possible, how are people deliverying 720p 23.976 footage to a exact broadcast time for a standard definition delivery?
    Matt
  • Walter Biscardi
    May 22, 2007 at 6:41 pm
    [Matt] “So if this isn’t possible, how are people deliverying 720p 23.976 footage to a exact broadcast time for a standard definition delivery?”
    We would capture to 720/59.94 (60) and edit that way for delivery to SD.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Matt Bishop
    May 22, 2007 at 6:50 pm
    Thanks for the response Walter, with this in mind is it possible to convert the 23.976 to 59.94 then downcovert to 29.97 via the KonaLHe. I have tried this using Cinema tools, but this only sped up the actual file.
    Thoughts?
    Matt
  • Matt Bishop
    May 22, 2007 at 8:01 pm
    Hey Walter, the only problem is that 720p 59.94 is still a non-drop timecode and when outputing for a broadcast master they are requesting drop frame.
    This downconvert is forcing the episode to run longer then the orginal non-drop 720p timeline. I was able to convert the 23.976 to 59.94 but again the problem still exists with the Dbeta running longer. Does anyone have any light they can shed upon this problem?
    Matt
  • Jeremy Garchow
    May 22, 2007 at 8:55 pm
    Shane Ross explains it on his blog:
    https://lfhd.blogspot.com/2006/09/online-workflow-overview.html
    Jeremy
  • Gary Adcock
    May 23, 2007 at 12:40 pm
    [Matt] “This downconvert is forcing the episode to run longer then the orginal non-drop 720p timeline. I was able to convert the 23.976 to 59.94 but again the problem still exists with the Dbeta running longer. Does anyone have any light they can shed upon this problem?”
    A get a timecode calculator, first off.
    <https://siliconcolor.com/downloads/TimecodeCal.zip>
    Apple supports the SMPTE spec, which states that progressive content was meant to stay as non drop to faithfully match the film editing process.
    The spec was not modified to allow for DF,which is still required by the networks since all of the satellites that broadcast our content are over 10 years old and not capable of understanding the the digital signal no longer need to maintain the differing timing signals between audio and video to alleviate bleed over.
    While the timebase of the clip appears to be DF (23.98 or 95.94) in actuality the record/play heads are physically slowed down to better accommodate the realtime conversion process to SD.
    gary adcock
    Studio37
