Activity Forums Blackmagic Design Downconversion test
  • Downconversion test
    Posted by Tony Partam on October 26, 2005 at 1:37 pm
    I’ve done a downconversion test and have some results.
    I have footage at 1080p and done the digibeta copy using the realtime BM downconversion, i then used AfterEffects for downconversion with “reduce interlace flicker” at amount “1” and also copied it to DigiBeta
    I captured the two clips on SD timeline and exported still pictures, opened them as photoshop layers and voila…
    The Aftereffects result is much higher in resolution
    The BMD is too soft
    Maybe Decklink uses too much of flicker reduction.
    I have the pictures and i’ll be sending them to BMD guys.
    Tony Partam
    Tony Partam replied 20 years, 11 months ago 2 Members · 2 Replies
  • Luke Maslen
    October 27, 2005 at 4:23 am
    Hi Tony,
    Thank you for preparing the sample files and can you please send them to support[at]blackagic-design.com so we can take a look at them?
    Regards,
    Luke Maslen
    Blackmagic Design
  • Tony Partam
    October 27, 2005 at 9:15 am
    Hi Luke,
    i already sent them to pcsupport@blackagic-design.com and if i knew how to post pictures here, i would have done it.
    Thanks for your help
    Tony
