Activity › Forums › Blackmagic Design › Downconversion Problem…Again
Posted by Tony Partam on November 10, 2005 at 8:06 amI’ve done a downconversion test and have some results.
I have footage at 1080p and done the digibeta copy using the realtime BM downconversion, i then used AfterEffects for downconversion with “reduce interlace flicker” at amount “1” and also copied it to DigiBeta
I captured the two clips on SD timeline and exported still pictures, opened them as photoshop layers and voila…
The Aftereffects result is much higher in resolution
The BMD is too soft
Please tell me how to post pictures on this forum so i can share my experience…
Matt Dowling replied 20 years, 10 months ago 4 Members · 6 Replies -
Matt Dowling
November 10, 2005 at 9:38 amHi Tony,
We have done a pile of tests too – just have not yet posted them up but we will in the next few days.
We have compared our HD D5 down conversion (a 20k d/converter option on the deck), DeckLink hardware and software d/conversion, FCP and AE. We were coming from a 1080i/50 tape. The DeckLink d/converters stood up very well next to D5, AE looked the best which we expected. When we post the pictures you can decide for yourself.
You can not expect ANY realtime d/converter to look as good as a render from AE as it has unlimited time to process complex math. A hardware realtime conversion does not have that luxury. (well maybe teranex systems but they are designed to do one thing and they do it extremely well)
If you are expecting the realtime d/conversion to look the same as AE i think your expectations are a bit optimistic.
Regards,
Matt
Blackmagic Design -
Georg Misch
November 10, 2005 at 11:56 amHi!
How long does downconversion take in After Effects? And on which platform?
Thanks and kind regards
Georg
MISCHIEF FILMS
Goethegasse 1
A-1010 Wien / Vienna Austria
http://www.mischief-films.com -
Steen Dongo
November 11, 2005 at 2:01 amHi Matt,
I, like Tony, have major problems with the downconversion, as you’re probably aware if you’ve followed the threads on the subject. Let me just start by saying that I’m sure your claim of delivering broadcast quality software downconversion is justified. It’s just that we can’t get it to look like a broadcast quality that our national broadcaster will accept.
There is something weird going on that I just simply can’t figure out. We’ve also tried the Dual Link card as well and it still looked very, very blurred. And yes, we made sure that we set the system prefs for hardware downconversion. (And yes… the shots ARE proberly focused:)
We’ve tried just about anything to make it work and I would really appreciate some help.
Greetings
Steen Dongo
Footage: HDCAM 1080, 25PsF
Easy Setup: BM 1080i, 50Hz
FCS 5.0.3
Mac OS 10.4.3
BM Driver 5.1.2
Mac Dual 2.0, 3GB RAM, BM card in top slotWe have done a pile of tests too – just have not yet posted them up but we will in the next few days.
Regards,
Matt
Blackmagic DesignSteen Dongo
Matt Dowling
November 11, 2005 at 3:46 amHi Steen,
Thanks for the note, our d/converter assumes and interlaced image, while i agree 25PsF in theory is basically the same thing i can image that certain images would not look the best when d/converted from a PsF rather than Interlaced.
I’ll get the guys to run exactly the same test with the same footage as PsF instead of the 1080i/50 we ran from for the testing in the earlier post.
Cheers,
Regards,
Matt
Blackmagic Design -
Steen Dongo
November 11, 2005 at 8:28 amHi Matt,
Thank you so much for responding. I really appreciate you guys checking into this. As I posted elsewhere we were more or less forced into using the AJA 10MD3 for downconversion as nothing else seemed to do the job, short of using an HDCAM machine.
I know I can’t expect the same quality from a software downcenversion, but still it’s nice that you investigate this as it definitely cannot be meant to look so blurred. What I simply cannot understand is why the Dual Link card didn’t yield any results better than what we observed. It was this that lead me to conclude that most likely wasn’t an error on the equipment, but som strange setup thing going on.
greeting
Steen Dongo
Matt Dowling
November 11, 2005 at 9:50 amHi Steen,
I will be in Tokyo all next week but i have arranged Luke and Kris to take a look this – If there is a bug or an error with something we are doing, i want to know about it! And fix it!
Thanks for the detailed feedback, this really helps us try exactly the same thing you are.I’ll check in with Luke and Kris when i can next week to see what the results were.
Cheers,
Regards,
Matt
Blackmagic Design
