Activity Forums Sony Cameras Down load longer than real time!
  • Down load longer than real time!
    Posted by Robin Probyn on April 5, 2012 at 10:27 am
    Any idea,s why..? cant be normal?
    camera PMW500 UDF 50Mbps 1080/25p
    Card SXS 64 GB Pro
    Computer Mac Book Pro
    Single card sony card reader
    HDD Lacie rugged
    Shot put pro..set to quick check..ie data only..
    A 64 GB card is taking over 3 hrs to down load.. for just over 2hrs of footage.. this cant be right can it ?
    Robin Probyn replied 14 years, 5 months ago 4 Members · 5 Replies
  • Don Greening
    April 5, 2012 at 7:34 pm
    I don’t know the first thing about the 500 (wish I did) but if you have a camera USB file transfer port that can be hooked up to your laptop try doing a straight file copy from the camera to your external LaCie. If your LaCie rugged is like mine you’ve probably got FW800 and are using that from the laptop. See if the laptop’s estimated copy time is less than 3 hrs. It should be far less, because a simple USB connection copying to a SATA internal drive is about 28 min. for 64 Gbytes. Don’t expect that kind of transfer tiime going from USB to FW800 but it shouldn’t even be close to 3 hrs.
    If this setup I’ve recommended you try is faster, then it’s just a process of elimination as to where the restriction is within your regular file transfer routine.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Michael Slowe
    April 7, 2012 at 10:30 am
    I too don’t know the 500 but can say that downloading BPAV files from a full S X S 16 GB card from my EX 1 takes about 13 minutes. I hook up USB to my MacBook and take the files straight through the computer to a drive connected to the MacBook by firewire 800. 64 GB’s then would take about one hour, not three.
    Michael Slowe
  • Robin Probyn
    April 7, 2012 at 11:57 am
    They dont seem to be BPAV files.. shot UDF and ofcourse 50 Mbps.. but still very long down load time!!
    Way more than real time !!
  • Bruce Rawlings
    April 9, 2012 at 2:02 pm
    Had the same trouble. Solved by putting UDF SxS driver from Sony site on the MacPro I was using. Camera is superb.
  • Robin Probyn
    April 9, 2012 at 2:09 pm
    Ah ! some light in the tunnel..!! what was the driver? I was told there was no driver needed in the computer when using the ext card reader.. were you using the 17inch MBP with the slot?
    Yes nice camera.. the viewfinder was a bit disappointing.. same as the HDCAM /800 series but not very good.. I was told the encoding from camera to viewfinder was “cheap” and so the quality not great.
    But besides that yes really liked the camera.. quite light,easy on batteries,easy menu.. small -ish but not a toy camera..
