Activity Forums Adobe Premiere Pro Down FPS from 30fps to 24fps GRRRRR!
  • Down FPS from 30fps to 24fps GRRRRR!
    Posted by Mark Cansino on August 4, 2010 at 10:23 pm
    So I want to make some movies and broadcast work and I want a 24 FPS camera, BUT I don’t want to spend more than a grand. So I’m looking at a Canon Rebel T1i Still camera that shoots 1080p 30FPS video.
    It’s only 700$ so I figured it fits my price range and allows me to have the manual zoom and focus ability that I want to shoot video.
    NOW! it only shoots 30fps, or stupidly 20fps.
    So my question is, since a sub $1,000 DSLR cameras don’t shoot 24fps, is it going to look good downgrading 30fps to 24fps through Premiere or After Effects? Or should I wait till they shoot 24fps?
    Thanks ahead, and I apologize if I’m posting this question in the wrong place.
    Mark “Line” Cansino
    https://www.LineDetail.com | The LineDetail Drawing Co. | Art – Web Design – Flash Animation & Games
    Mark Cansino replied 16 years, 1 month ago 2 Members · 3 Replies
  • Mark Cansino
    August 5, 2010 at 7:41 pm
    BTW I just found out for $100 more I can get the T2i that has 24fps.
    But I’d still like to know the answer 🙂
    Thanks ahead,
    -Line
  • Vincent Rosati
    August 6, 2010 at 2:41 am
    Generally, using default methods to reduce framerate from 30 to 24fps will introduce an awkward cadence to your motion.
    I haven’t had to do this for some time, but I don’t recall there being a ‘correct’ way to do it in Premiere without a plugin.
    I always did this in AE with Twixtor. Instead of simply dropping frames it would redraw frames. I believe that AE now has this function in the default installation.
    I’d look through the After Effects archives. I think Andrew Kramer has an AE tutorial for changing framerates in AE, it might be searched by ‘frame rate’, of ‘ time remapping’ or something.
    https://library.creativecow.net/articles/kramer_andrew/fps/video-tutorial.php
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Mark Cansino
    August 6, 2010 at 2:53 am
    Thanks Vincent!
