Activity Forums Compression Techniques DOWN CONVERSION ISSUE: From MXF (1080i AVC Intra) – MBAFF “interlacing” to DVCPRO
  • DOWN CONVERSION ISSUE: From MXF (1080i AVC Intra) – MBAFF “interlacing” to DVCPRO
    Posted by Iban Txo on March 23, 2012 at 10:40 am
    Hi!
    I am trying to down convert a MXF:
    Stream #0:5: Video: h264 (High 4:2:2 Intra), yuv422p10le, 1920×1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 25 tbn, 50 tbc
    It has a MBAFF interlacing inside (Mediainfo tells it).
    With ffmpeg I can get a DV, but it is de-interlaced and I want to be interlaced with the original “fields”.
    How can I get it using ffmpeg?
    Many Thanks
    Iban Txo replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
