Activity Forums Compression Techniques doubts about codecs and compressions
  • doubts about codecs and compressions
    Posted by Michel Domaine on November 11, 2010 at 2:28 pm
    Hi everybody,
    First of all I am sorry for my english.
    I lost a night for this, so I thought to ask to the Cow!
    I had to edit a video assembling a lot of different videos, most of all mp4 or mov in h264 codec (not a great quality).
    I worked and I’ve exported to animation to have an intermediate codec.
    Then, after some client’s correction, I had to compress in the best possible quality for a wall projection from a pc.
    I used compressor and I made three videos (1024×576, 10 minutes long) to test:
    -mpeg4 at the best
    -quicktime h264 at the best
    -mpeg2 at vbr average bitrate 18, pick bitrate 30
    What I saw is that:
    – mpeg4 and h264 degraded a lot the contrast and show a lot of broken pixel, it was really bad.
    – mpeg2 (with compressor saying 720 pal 16:9) wasn’t 1024×576, but 720×404, it had less details on the graphics, but contrast and colors were good, near to the animation.
    So my questions are:
    – why compressor makes mpeg2 pal 16:9 so little and not in a standard 1024×576?
    – we know that in a lot of case best codec for internet is mp4 or mov h264, but for a presentation or a projection (as in my example) which is the best format and codec?
    thanks everyone and sorry if my description was so long!!! 😉
    Michel Domaine replied 15 years, 10 months ago 2 Members · 4 Replies
  • Chris Blair
    November 12, 2010 at 2:02 am
    Michel Domaine wrote:
    -mpeg4 at the best
    You’d have to provide a lot more details about your settings before anyone could help. That’s not really enough information. H.264 can look as good as MPEG2 at nearly half the data rate, so you shouldn’t see as big a difference in quality. MPEG2 can be compressed to both SD and HD sizes, and you’re using square pixel, widescreen SD Pal at 1024×576. My guess is you have the pixel aspect set wrong in your settings and it’s resizing based on that….but that’s just a guess.
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
    Read our blog http://www.videomi.com/blog
  • Michel Domaine
    November 12, 2010 at 11:23 am
    Thanks for the answer Chris!
    First of all, I used compressor 3.5.3
    Here I put the settings from the info window:
    MPEG4
    Description: MPEG-4 video with AAC audio at 48kHz. Settings based off the source resolution and frame-rate.
    File Extension: mp4
    Estimated size: 99.99 MB
    Audio Encoder
    Format: MPEG4
    Sample Rate: 48.000kHz
    Channels: 2
    Bits Per Sample: 16
    AAC encoder quality: high
    Data rate: 256 Kbps
    Video Encoder
    Format: MPEG4
    Width: (100% of source)
    Height: (100% of source)
    Selected: 1024 x 576
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: 25
    Frame Controls: Automatically selected: Off
    ISMA Profile: 0
    Variable bit rate, high quality
    Enhanced Podcast: Off
    MOV H264
    Description: H.264 video with stereo AAC audio. Settings based off the source resolution and frame-rate.
    File Extension: mov
    Estimated size: unknown
    Audio Encoder
    AAC, Stereo (L R), 48,000 kHz
    Video Encoder
    Format: QT
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 25
    Codec Type: H.264
    Multi-pass: On, frame reorder: On
    Pixel depth: 24
    Spatial quality: 100
    Min. Spatial quality: 25
    Temporal quality: 50
    Min. temporal quality: 25
    MPEG2
    Description: MPEG-2 Program Stream with MPEG audio at 48kHz. Settings based off the source resolution and frame-rate.
    File Extension: mpeg
    Estimated size: 1.3 GB
    Type: MPEG-2 program stream
    Video Encoder
    Format: M2V
    Width and Height: Automatic
    Selected: 720 x 576
    Pixel aspect ratio: PAL CCIR 601 (16:9)
    Crop: None
    Padding: None
    Selected: 25
    Start timecode from source
    Aspect ratio: Automatic
    Selected 16:9
    Field dominance: Automatic:
    Selected Progressive
    Average bit rate: 17 (Mbps)
    2 Pass VBR enabled
    Maximum bit rate: 30 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 12, Structure: IBBP
    Audio Encoder
    Format: MPEG
    Channels: 2
    Bits Per Sample: 16
    The problem is that with compressor I can’t change pixel aspect ratio on mpeg2, so it’s impossible to put it square.
    And it’s really strange, cause in the finder and with Quicktime dimensions are 720×404. If I use vlc it recognize the video like pal 16:9 and show it at 1024×576.
  • Chris Blair
    November 12, 2010 at 11:43 pm
    Quicktime reports some weird things in it’s inspector. But your MPEG2 settings show 720×576 at 16:9, which would basically be changing your pixel size from square (1024×576) to rectangular. So you’re fine there.
    The same thing happens in NTSC world with Quicktime H.264. I can output a 720×486 rectangular pixel 16:9 video and using Quicktime I HAVE to output an 864×486 file to get it to display properly in Quicktime.
    The rest of your settings look ok to me, so maybe somebody else can chime in.
    Chris Blair
    Evansville, IN
  • Michel Domaine
    November 13, 2010 at 12:17 pm
    Maybe it’s also cause it’s an mpeg and Quicktime doesn’t love so much mpeg…
    But now, which is the best codec for a presentation or a projection (that could be the same for a good archiving…) ?
    And another question… how can I make a mp4 with h264 codec in compressor? I didn’t found this setting possible.
    Thank you Chris and thanks to everyone.
