Activity Forums Adobe After Effects Expressions Doubt about an expression
  • Doubt about an expression
    Posted by Xdominguez Pukkas on December 13, 2012 at 2:03 pm
    So I posted this on the wrong forum:
    I know it is simple but I am clueless when it comes to expressions:
    I have a text I want to randomly change the color (using the tint effect) every two seconds for an undetermined amount of time. I have been copying keyframes, but it is no longer feasible.
    What code should I use?
    Thank you all!
    Xdominguez Pukkas replied 13 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 13, 2012 at 6:40 pm
    Try this on “Map White To”:
    period = 2;
    seedRandom(Math.floor(time/period),true);
    random([0,0,0,1],[1,1,1,1])
    That will give you randoms colors from the entire spectrum every two seconds.
    Dan
  • Xdominguez Pukkas
    December 17, 2012 at 12:31 pm
    This works!
    I’d like the colors to change gradually, as if dissolving, instead of changing abruptly. What expression should I use?
