Activity › Forums › Adobe After Effects › Double stroke on open path in After Effects
Nikki Van onna replied 3 years, 6 months ago 3 Members · 14 Replies
Nikki Van onna
March 20, 2023 at 2:31 pmThank you, Filip. That’s a pity, cause I also want to use non-curved lines. It’s strange that it doesn’t distribute well on a corner (image01), if I apply the offset path it work just fine (image02).
Still hope there is a solution for this, it seemed like such an easy thing; a double stroke. Never expected it to be this challenging in AE. -
Filip Vandueren
March 20, 2023 at 4:14 pmOf course My implementation of using text has its own shotcomings, but apart from that; offsetting bezier curves is mathematically a difficult problem as you can read here:
https://pomax.github.io/bezierinfo/#offsetting
Nikki Van onna
March 21, 2023 at 7:43 amThank you Filip, that goes way above my head. 😀
Offsetting doesn’t seem to be the problem though, that works quite well.
It’s just a pity that you can’t make a stroke style or a path that is still handled as a stroke when offsetting. Well, back to the drawing board! Again, thank you for all your help.
