Activity Forums Adobe After Effects Double-sided layers?
  • Double-sided layers?
    Posted by Simon Beaulieu on April 23, 2010 at 4:01 pm
    Thought I’d check with you guys to see if any of you might have an answer to this question in After Effects:
    Is it possible to have a solid layer (with 3d enabled) have a different color on each side of it, as in if i were to flip it or have a camera pan around either side would be a different color? Or even, having a raster image with a different image on each side?
    I tried many things but the only solution I could find would be having 2 layers back to back and having them both parented on a null layer and doing all the manipulation of the null layer… is there another way to do this without having to create 3 layers?
    Serge Hamad replied 16 years, 4 months ago 4 Members · 4 Replies
  • Andy George
    April 23, 2010 at 4:57 pm
    [Sebastien Mouttet] “is there another way to do this without having to create 3 layers?”
    You could do it using 2 layers by skipping the null and parenting the front layer to the back layer.
    Here is a cool expression by Dan Ebberts that will make a layer invisible when facing away from the
    camera.
    https://www.motionscript.com/design-guide/invisible-facing-away.html
    -Andy
  • Simon Beaulieu
    April 23, 2010 at 5:15 pm
    Merci beaucoup guys, appreciate it!
  • Brian Charles
    April 23, 2010 at 5:49 pm
    Card Wipe or Card Dance
  • Serge Hamad
    April 23, 2010 at 6:27 pm
    Shatter can also apply a second layer as a texture in the back.
    Forces must of course be set to (0). The cool thing with Shatter is that you can also give a depth to your layer so it doesn’t totally disappear when oriented to 90 degrees.
    Salut.
    Serge
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
