Activity Forums Adobe Photoshop Double selection possible?
  • Double selection possible?
    Posted by Gary Weaverton on April 17, 2007 at 12:07 am
    Hello,
    When I make a selection using my Lasso Tool, and then want to make another (separate from the first) selection on the same layer/image, I lose the first selection I made.
    Is it possible to keep the first while making the second?
    Gary
    P.S. I’m using CS
    Gary Weaverton
    Photographer/Illustrator
    gary.weaverton@gmail.com
    Darby Edelen replied 19 years, 5 months ago 3 Members · 3 Replies
  • Tiffanib
    April 17, 2007 at 8:55 pm
    Yes, hold down the shift key while you make your second selection. That will add it to your first selection.
    Tiffani B
  • Gary Weaverton
    April 17, 2007 at 11:08 pm
    Wow, that was easy!
    Gary
    Gary Weaverton
  • Darby Edelen
    April 19, 2007 at 12:17 am
    Just so you know what else is available, if you hold down opt/alt while using a selection tool you can subtract from your selection area as well.
