Activity Forums Adobe After Effects Double Pass Render?!
  • Darby Edelen
    May 2, 2007 at 11:16 pm
    I’ve never experienced this. There’s only one instance of the composition in the Render Queue? It finishes it once and then goes back and does the whole thing over again?
  • Darby Edelen
    May 2, 2007 at 11:18 pm
    I should’ve asked a couple more questions =)
    What codec do you generally render to? Do you notice it happening only when you’re using certain render settings? Are you rendering to MPEG-2?
