Activity › Forums › Adobe Premiere Pro › “Double letterbox” with WMV HD export.
  • “Double letterbox” with WMV HD export.
    Posted by Eric Jurgenson on May 16, 2005 at 2:10 pm
    I’m rendering a 1080i movie from PPRO 1.5.1 shot with the Sony Z1U to WMV 9 HD (1080i). It renders (slowwwlly), but the aspect ratio is wrong. It “letterboxes” the already 16×9 image to create a horizontally stretched and letterboxed image. There seem to be no obvious encoder settings to make this right. Any suggestions?
    Eric Jurgenson replied 21 years, 4 months ago 2 Members · 2 Replies
  • Steven L. gotz
    May 16, 2005 at 3:02 pm
    Hopefully I can list all of the pertinent settings for you. This is how I would export to play on my AVeL Linkplayer2 to display on my Sony HDTV. And yes, it is quite slow. Around 8 times realtime on my system.
    Start with the WMV9 1080 60i preset. Do not choose the anamorphic, just the plain one.
    Under video, it is Windows Media Video 9 and I generally use a constant bit rate if the video is not an hour or more.
    Under audio, I change from the 9.1 professional to the plain 9.1 because of the Linkplayer.
    Under audiences, I select a frame rate of 29.97, a custom pixel aspect ratio of 4:3, a frame width of 1440 and a height of 1080. I move the bitrate settings to 8000.00 and 100. And the audio is set to 128kbps, 48KHz, stereo (A/V) CBR
    If you are playing it on a PC, you might want to change to 1280X720 square pixels. That actually works just fine on a Linkplayer connected to an LCD or DLP TV with 1280X720 pixels. Saves file space since there is no need for more resolution than the HDTV can actually show.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Eric Jurgenson
    May 16, 2005 at 4:45 pm
    Thanks, Steven. I’ll try it out.
