Activity Forums VEGAS Pro Double image on Slo mo event
  • Double image on Slo mo event
    Posted by Mike Hinkel on May 15, 2012 at 4:44 pm
    Trying both an enveolope and ripple to slo mo an eagle flying I come up with a double image of the bird. I am rendering to 720p internet. The source file is a 720p .MOV using the HDV 720-30p (1280×720, 29.970 fps)template. Any suggestions on getting a single image in slow motion?
    Mike Hinkel replied 14 years, 3 months ago 2 Members · 2 Replies
  • Angelo Mike
    May 15, 2012 at 5:26 pm
    Right click on the event, click properties, then click “Disable resample”. I do this whenever I render out to a different frame rate to avoid ghosting. I haven’t tried it in your situation, but it might work.
    Also, make sure that your project properties match your media.
  • Mike Hinkel
    May 15, 2012 at 6:10 pm
    Thanks Angelo, that did the trick. For as much as I use slow motion i’ll have to write that down or at least copy the thread to my tips file….;^)
