Activity › Forums › Adobe After Effects › double frame in position animation
Posted by Rosy Rodrigues on September 1, 2005 at 3:13 pmCan anyone please tell me why is it that i see double frame effect when i animate an objet left to right in a 720X576 comp. in a duration of two seconds. it does not look smooth even after rendering. Is it because it oves too fast? It looks like a jitter but is not. is there a way to correct this? please help.
rosy
Rosy Rodrigues replied 21 years ago 2 Members · 7 Replies -
Deleted User
September 1, 2005 at 8:30 pmHello Rosy,
Did you enable motion blur? This will give you a smoother more natural movement. Also a object moving across that screen size in 2 seconds will look abit jerky but try motion blur and I think that should solve the problem as adds a blur on the movement.
Hope this helps?
Leo 🙂
Rosy Rodrigues
September 2, 2005 at 9:48 ami did try motion blur but that makes the image blurry and not crisp.
Deleted User
September 2, 2005 at 12:41 pmHave you tried outputting to a NTSC or PAL Broadcast monitor I think you’re in the states I’m not so sure. As sounds like the jerky motion of the rectangle moving across left to right 2 secs keyframe could be down to where the fields are not displayed properly on a computer monitor.
So when you output to Broadcast monitor you will see interlaced fields and should look alright.
Have a go at that or exporting to tape and let me know how you get on with it?
Leo
Rosy Rodrigues
September 2, 2005 at 5:32 pmAs a matter of fact i did check the output on a broadcast monitor and it still showed the same. I work in PAL format. The tape dump also showed the same jerky movement.
Why does this happen?
Deleted User
September 3, 2005 at 1:15 amHello Rosy,
It does this as you are moving an object over a short space of time and it’s having an interlaced effect. Try maybe a ease in and out so it accelerates and decelerates the animation. Or email me your project file and I’ll have a look and see if I can reduce the strob ing effect ov er the movement.
Leo 🙂
LEO BAKER
SYNC FILMS
Web: http://www.syncfilms.com
E-Mail: leo@syncfilms.com -
Rosy Rodrigues
September 5, 2005 at 3:46 pmI am sending you the project file. I tried a longer duration for the movement but result still remains the same. Have a look at it and let me know what u think.
Rosy.
Rosy Rodrigues
September 5, 2005 at 3:48 pmI am sending you the project file. I tried a longer duration for the movement but result still remains the same. Have a look at it and let me know what u think.
Rosy.
