Activity Forums Adobe After Effects Double exposure using channels – How to ?
  • Double exposure using channels – How to ?
    Posted by Shrinivas Ananthanarayanan on December 3, 2020 at 1:21 pm
    Hey all
    Im trying to create this effect that i am able to achieve in Photoshop using some actions.
    It utilizes the channel mixer and the Hi-pass filter to be able to control the blending.
    Any suggestions on how i could achieve this in After effects ? or if there exists a plugin that does something similar ?
    thank you !
    sh
    Robert Müller replied 5 years, 8 months ago 3 Members · 3 Replies
  • Michael Szalapski
    December 4, 2020 at 7:36 pm
    There’s a channel mixer effect in AE. Have you tried working with it?
  • Shrinivas Ananthanarayanan
    December 14, 2020 at 7:06 am
    yes i have , but have been unable to recreate the effect. Any suggestions on how to go about getting the red and cyan tones ?
  • Robert Müller
    December 14, 2020 at 9:24 am
    For this particular case you dont need to mess with the channels at all. As far as I can tell this example does not use the corresponding channels in a true fashion, because (for example) the red layer does not seem to have a background. The easiest way to achieve this
    – Put both videos/images on top of one another
    – Add a Levels or Curves effect to both of them but do nothing yet
    – Add a Tritonus to both of them. Turn the Highlight s and Midtones on both layers to white and the shadows to Red and Cyan respectively
    – Mess with the Levels/Curves until you see the details of the image you want to show
    – Set the blend mode for the top layer to multiply
