Activity Forums VEGAS Pro Double Exposure effect?
  • Double Exposure effect?
    Posted by Matt Schwartz on August 27, 2007 at 11:39 pm
    How can I do a video double exposure effect? I have played around with compositing,parent and child tracks but not sure exactly how to do this or if it is possible, thank you.
    Edward Troxel replied 19 years ago 2 Members · 3 Replies
  • Matt Schwartz
    August 28, 2007 at 1:01 am
    OK I figured that out, I can change the event opacity envelope, HOWEVER, how can I FX keyframe – automate this? So I can go in and out of opacity…. IS there an FX tool for this?
  • Matt Schwartz
    August 28, 2007 at 5:59 am
    Got it. Needed to put points on the composite opacity track not event, envelope.
  • Edward Troxel
    August 28, 2007 at 1:46 pm
    Good to see you figured it out.
    As you’ve seen, on the event level, you can change to one specific setting. On the track level, you can add an envelope that can be changed over time OR just make a specific change using the levels slider.
    Edward Troxel
    JETDV Scripts
