Activity Forums Apple Final Cut Pro Legacy Double entries for sequence & capture
  • Double entries for sequence & capture
    Posted by Chris Borjis on September 19, 2007 at 3:56 pm
    I’m not sure when it happened but I’ve just noticed that I have double entries of all my easy setups, both in the sequence and capture sections.
    for example I have 2 “NTSC 10-bit” entries.
    If I manually delete them all within final cut, they all come back when I relaunch final cut.
    I trashed/restored the prefs and that did nothing.
    I looked in the system drive, library, apps, section and cannot find double entries, just the one set for final cut and the one set for blackmagic hardware.
    Anyone have an idea what I can do to get rid of the doubles?
    I think they may have appeared when I installed FC6.
    Rafael Amador replied 19 years ago 2 Members · 1 Reply
  • Rafael Amador
    September 20, 2007 at 12:33 am
    Borgis,
    At least in my G5 I’ve got “Easy set-ups” in three different places (mess):
    – Library>Applications Support> FinalCut Pro System Support> Custom Settings
    – Applications>FinalCut Additinal Easy Set-ups
    – Users> My Self> Library>Prefferences>Final Cut Pro User Data>Custom Setting
    When I have installed the Blackmagic and the Sheer codec his “Easy Set-ups” has gone to those places. Just delete those that you don’t need.
    Rafael
