Activity › Forums › Apple Final Cut Pro Legacy › Double checking 25p workflow
  • Double checking 25p workflow
    Posted by Andries Dillen on February 17, 2009 at 5:48 pm
    Hi Cow,
    I was wondering if the following workflow is the right one to use when editing footage shot in 25p with the dvx100.
    Open a new project.
    When prompted for sequence settings just select dv-pal 48khz.
    Go to sequence settings panel again and change the field dominance from lower to none.
    Is this the right way to edit 25p footage?
    Tnx in advance,
    Andries
    Andries Dillen replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
