Activity Forums VEGAS Pro Double buttons in sony architect
  • Double buttons in sony architect
    Posted by Pat Bailey on November 13, 2009 at 4:07 pm
    Rendered in sony vegas 1st is wav and 2nd is mpeg at 8000bits as you recommended. I make sure they both have the same title.
    I delete any earlier copies I have tried.
    I check there is no other copy in sony architect
    When I try to copy paste into sony architect it makes two copies and shows up two buttons and text.
    I render with no markers but I designate the area I want rendered and I tick box that says render loop region only
    Help
    Thank you
    Pat
    Pat Bailey replied 16 years, 10 months ago 3 Members · 4 Replies
  • Theo Van laar
    November 13, 2009 at 4:12 pm
    What most people do is render the video in Vegas as MPEG2 and render the audio also in Vegas as AC3 (not WAV) as a separate file. In DVDA you just import the MPEG2 file and the AC3 file will follow automaticly (if you had given it the same name and stored it in the same folder).
    Theo
  • Pat Bailey
    November 13, 2009 at 5:00 pm
    I need the highest quality music that is why I render to wav rather than ac3.
    How can I get sony architect to only show one button when I add wav and mpeg 2?
    Thank you
    Pat
  • Adam Rose esq.
    November 13, 2009 at 5:49 pm
    add the mpeg2 only
    then change the media properties (top right) for the audio, to the wav you have rendered
  • Pat Bailey
    November 13, 2009 at 5:58 pm
    Hi Adam It worked beautifully. Thank you very muchI have spent hours today trying to sort it out by keep rendering etc.
    So THANK YOU
    Best wishes
    Pat
