Activity › Forums › Adobe Illustrator › Dotted spiral with progressively larger dots – BUT with similar distances
  • Dotted spiral with progressively larger dots – BUT with similar distances
    Posted by Silvan Nietlisbach on June 19, 2021 at 9:26 pm
    Hi guys,
    I’d like to create a dotted spiral with progressively larger dots, exactly like the one shown in the picture in the attachment or in this tutorial: https://www.youtube.com/watch?v=cmd1wBNE7P0
    However, the problem with this spiral is, that the distance between the dots is bigger for smaller dots than for the larger dots (the distance between the edges of the dots becomes smaller from the inside to the outside). Larger dots can even overlap. This is not what I want.
    What I would like to have is similar distances between the BORDERS of the dots, independently if the dot is large or small. In other words: the smallest point should be the same distance from the second smallest point – as the largest point is from the second largest point. I hope you are understanding my issue.
    How can I do that? Your help / links to tutorials is very highly appreciated! Many thanks for your support and best regards, Silvan
    Silvan Nietlisbach replied 5 years, 3 months ago 1 Member · 1 Reply
  • Silvan Nietlisbach
    June 20, 2021 at 7:57 pm
    Hi Guys – any creative suggestions highly appreciated! 🙂
