Activity Forums Adobe After Effects Expressions Dots – Grid Transition
  • Dots – Grid Transition
    Posted by Rafael Cruz on March 9, 2009 at 10:22 pm
    I need to create a grid-like layer of slightly random dots which cross the screen in a transition. I realize this is quite simple, but I’m having trouble manipulating the dots properly with particular, and think an expression could really make it easier.
    Ideally, I would like the dots to appear from left to right by adding the dots (rather than using keyframes to actually move them). The result is, a bunch of dots being added from left to right (not moving) covering the screen for a moment before disappearing screen-right.
    The problem with particular is that, while the grid dots can be randomized well, the perimeter of the grid is pretty much fixed. I haven’t been able to, say, extend any of the rows of dots out ahead of the rest (like fingers on a hand of grid dots).
    I can solve that by breaking the grid down into single rows and duplicating those screen-crossing rows into the “broken” grid I’m looking to create, but then I can’t get the right randomness on the back end of the dot trail.
    is anyone familiar with an expression i can tweak for this?
    ~Raf
    Jonan Grobler replied 12 years, 3 months ago 3 Members · 4 Replies
  • Filip Vandueren
    March 9, 2009 at 11:40 pm
    Is this what you need ?
    step 1:
    Animate a gradient from left to right in an oversized comp.
    Step 2:
    Add Horizontal Turbulent displace:
    Step 3:
    Precomp, Crop and add a Mosaic Effect:
    Step 4:
    Multiply or Stencil Luma, a grid of dots (I made this with Generate->Circle and Stylize->Motion Tile)
    Step 5:
    Finished.
  • Rafael Cruz
    March 10, 2009 at 12:59 am
    Yes!
    Thank you filip. So clear.
    This looks like it’ll work.
  • Filip Vandueren
    March 10, 2009 at 1:35 am
    Right now, the trails are actually all of equal length, just scattered.
    This can be easily mimicked by overlaying some blurred out fractal-noise over the original gradient:
  • Jonan Grobler
    May 30, 2014 at 10:02 pm
    Oh wow. You just saved my life sir. 😀
    Jonan Grobler
    Editor/Motion Graphics
    GTG MOTION PICTURES
    filmstudio.co.za
