Activity › Forums › Apple Final Cut Pro Legacy › dots dash dot dot dash
Posted by Lucian Evans on July 11, 2007 at 10:11 amhi
I shoot DVpal and edit on a kona3 FCP suite. When importing footage there has always been black and white dashes outside action safe at the top of the screen. This has not been a problem when the film has been viewed on a tv but when viewed via DVD these dashes are sometimes seen.
I realise i can resize individual clips to get rid of this or even export the whole timeline and resize but both these methods take time with rendering.
Is there a way of losing these during import?
cheers
Lucian
Martin Baker replied 19 years, 2 months ago 6 Members · 8 Replies -
Stuart Simpson
July 11, 2007 at 10:55 amHow are you digitising? Firewire, component, SDI? What deck are you using?
Are the dots only showing up when you do a letterbox?
-Simmie
2 G5 – Kona LH
3 G4s – Cinewave
1 xbox360, 1 PSP, 1 PS2 & a Gamecube
https://www.speak.co.uk -
Nick Meyers
July 11, 2007 at 11:19 amand is it that the dots are visible on the DVD on a computer, rather than a TV?
a lot of rubbish that used to be safely outside of viewing area is now visible thanks to viewing on computers.
no need to crop shot by shot.
you should be able to crop your entire show.you can nest it in another timeline, and crop the nest.
if you’ve already rendered this’ll mean you have to re-render the whole show.alternatively you can ad a slight crop when you compress it in Compressor.
nick
Lucian Evans
July 11, 2007 at 12:11 pmHi
I’m digitising via Sony DSR1500AP, SDI. They tend be there when in letterbox.
cheers
L -
Lucian Evans
July 11, 2007 at 12:15 pmYep, i’ve been cropping in the timeline, cropping in compressor but what i really want is to have something set up to crop on capture.
Nick Meyers
July 11, 2007 at 12:21 pm“I shoot DVpal and edit on a kona3 FCP suite”
“what i really want is to have something set up to crop on capture.”
“I’m digitising via Sony DSR1500AP, SDI.”so that’s either some magic in the Kona card (you could try the Kona forum)
or routing thru some other bit of hardwarenick
Gary Adcock
July 11, 2007 at 12:38 pm[Lucian] “uite. When importing footage there has always been black and white dashes outside action safe at the top of the screen. This has not been a problem when the film has been viewed on a tv but when viewed via DVD these dashes are sometimes seen.”
Lucian
You have to crop it out.
What you are looking at a visual representation of the LTC timecode track that is normally in what is called the overscan. It has always been there, your process of editing prior to this did not capture it. FW capture automatically crops this data out, the only time you see it is with 3rd party capture cards in Uncompressed workflows
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Will Griffith
July 11, 2007 at 2:52 pmIn your final output timeline you could also just apply a couple pixel black matte to the area
if you don’t want to crop everything.Will Griffith
Producer/Editor -
Martin Baker
July 11, 2007 at 3:27 pmIf you’re shooting in 16:9, then the lines are likely to be the widescreen signalling flag as recorded on the tape. These lines tell TVs that the signal is 16:9 and aren’t present for 4:3 footage.
AFAIK it’s not possible to crop the lines off on the FCP side during capturing but it’s worth looking into the DSR menus to see if you can disable the WSS flag on the output. Other than that, your best bet is probably blanking them out in Compressor.
Martin
Digital Heaven, London UK
Unique plug-ins and tools for Apple Pro Apps
Avid2FCP
For Avid editors learning FCP
