Activity › Forums › Adobe After Effects › Dots appearing over time (fastest/most efficient method)
  • Dots appearing over time (fastest/most efficient method)
    Posted by Adam White on April 2, 2013 at 8:03 pm
    I’m fairly familiar with After Effects, and have dipped in and out of it for a few years now.
    I have a pretty straightforward animation to create with a logo, and I wanted to post on here to see what the experts think would be the most efficient way of doing it.
    I have a logo that is made up of separated dots (the dots are quite far apart from each other and do not touch each other). All I want to do is have the logo build up over time with each dot appearing in succession until the whole word/logo is revealed. Ideally I’d like to mess with the sequence of the way the dots appear a little so that the way it builds up looks a bit more interesting.
    I have used “auto trace” command to create masks around all the dots, which worked fine. Applying the “Stroke” effect works OK but looks just like a linear wipe. I’ve separated each letter of the word in the logo so each has it’s own layer, and then set the “Stroke” effect on each to “All Masks/Stroke Sequentially”
    At the moment I’m guessing that I need to break up each letter into a layer per dot, apply the “Stroke” effect and set it so that it reveals just one of the dots in the letter per layer, and then play around with the sequencing of the dot layers in the timeline to get a less linear look.
    But as I am by no means an After Effects expert so I feel that I might be doing this a horrendously inefficient way – if anyone has any other ideas to complete the task at hand faster I would be most grateful for any input.
    Many thanks,
    Adam
    Tudor “ted” jelescu replied 13 years, 5 months ago 3 Members · 2 Replies
  • Cassius Marques
    April 2, 2013 at 9:21 pm
    Where does this logo came from? Can’t you break it apart in its creation software and import separated pieces so you can be free to do whatever you want?
    But as Dave said, if you can recreate the dots in AE, you’ll probably have a better control.
    Copying and pasting an animation (scale maybe) between layers, then sequencing them gives a way better look than any stroke reveal effect IMO.
  • Tudor “ted” jelescu
    April 3, 2013 at 7:22 am
    I would suggest checking out Newton2 – it’s quite easy to create complex animations with just a few clicks once you have your logo split into shapes.
    https://motionboutique.com/newton
    Tudor “Ted” Jelescu
    Senior VFX Artist
