Activity › Forums › Adobe After Effects › Doted Lines – Street Marking
Posted by Noe Marti on February 16, 2006 at 6:58 pmIs there any trick or PlugIn that creats doted lines, rectangle style, like street markings ? – moving around a mask would be nice.
Vegas and Line Filter does not work.Editing-jos replied 20 years, 7 months ago 5 Members · 11 Replies -
Sam Moulton
February 16, 2006 at 7:38 pmi just did a dashed line by applying the venetian blind transition to a long thin solid maybe that would work unless your lines are curved
Noe Marti
February 16, 2006 at 7:57 pmmy lines are curved 🙁
would be nice if adobe could pimp the vegas filter ……
Noe Marti
February 16, 2006 at 10:34 pmthat wont work, I need something like the “Vegas” effects (animatable) but with rectangles. It is a closed curvy border.
Spritemaster
February 16, 2006 at 10:48 pmHow about multiple vegas or stroke effects? Try to make a single rectangular blob along the mask at a certain offset, then duplicate the effect and use expressions to space the offsets so as to get a dashed line. I’m not in front of AE now and I can’t remember if you can get an index for the effect number within a layer, but if not just duplicate the layer itseld and use a single stroke effect on each layer; then you can use the “index” variable in an expression as a multiplier for the offset position.
Does this do what you’re after, or am I misinterpreting your question?
AA
Sam Moulton
February 16, 2006 at 11:27 pmif they don’t move you could just draw the lines in Illustrator.
Dflamholc
February 16, 2006 at 11:37 pmyeah, easiest way ive done dotted lines that write themselves out was to draw them in illustrator and import to ae and apply the write-on effect, using the path from illustrator as a motion path. don’t know if that would work for you .. :)/d
Sam Moulton
February 16, 2006 at 11:53 pmHey – this is the first time I figured out the answer to one of the questions.
I added matte choker to vegas and then alpha levels. In vegas i set the hardness to 1, the start middle and end opacity to 1, and the color to white and blend mode to transparant
I then added matte choker and ran up geometric softnes to 4 and choked the lines until i got square ends. The lines were not a solid color so I added alpha levels and cranked the input white clear down to 0 which got rid of the gray. Now the layer can be used as a luminance track matte for a yellow layer.
square end stripes…. wow! I’m so proud of myself.
Editing-jos
February 17, 2006 at 1:11 amwasnt it possible to just use TEXT on a Path? You can animate that!
You can use the minus for the line. In the ascii code are still more elements to use. Or special fonts with signs.
Noe Marti
February 17, 2006 at 10:27 amThank your for all Ideas. The “Minus” is the solution. That’s it ! Thank you for this great Idea,
Text on Path and then use the minus – it’s that simple.
