Activity Forums Adobe After Effects Expressions Doted Lines – Street Marking
  • Doted Lines – Street Marking
    Posted by Noe Marti on February 16, 2006 at 6:58 pm
    Is there any trick or PlugIn that creats doted lines, rectangle style, like street markings ? – moving around a mask would be nice.
    Vegas and Line Filter does not work.
    Editing-jos replied 20 years, 7 months ago 5 Members · 11 Replies
  • 11 Replies
  • Sam Moulton
    February 16, 2006 at 7:38 pm
    i just did a dashed line by applying the venetian blind transition to a long thin solid maybe that would work unless your lines are curved
  • Noe Marti
    February 16, 2006 at 7:57 pm
    my lines are curved 🙁
    would be nice if adobe could pimp the vegas filter ……
  • Sam Moulton
    February 16, 2006 at 9:05 pm
    you might try adding one of the warp filters
  • Noe Marti
    February 16, 2006 at 10:34 pm
    that wont work, I need something like the “Vegas” effects (animatable) but with rectangles. It is a closed curvy border.
  • Spritemaster
    February 16, 2006 at 10:48 pm
    How about multiple vegas or stroke effects? Try to make a single rectangular blob along the mask at a certain offset, then duplicate the effect and use expressions to space the offsets so as to get a dashed line. I’m not in front of AE now and I can’t remember if you can get an index for the effect number within a layer, but if not just duplicate the layer itseld and use a single stroke effect on each layer; then you can use the “index” variable in an expression as a multiplier for the offset position.
    Does this do what you’re after, or am I misinterpreting your question?
    AA
  • Sam Moulton
    February 16, 2006 at 11:27 pm
    if they don’t move you could just draw the lines in Illustrator.
  • Dflamholc
    February 16, 2006 at 11:37 pm
    yeah, easiest way ive done dotted lines that write themselves out was to draw them in illustrator and import to ae and apply the write-on effect, using the path from illustrator as a motion path. don’t know if that would work for you .. :)/d
  • Sam Moulton
    February 16, 2006 at 11:53 pm
    Hey – this is the first time I figured out the answer to one of the questions.
    I added matte choker to vegas and then alpha levels. In vegas i set the hardness to 1, the start middle and end opacity to 1, and the color to white and blend mode to transparant
    I then added matte choker and ran up geometric softnes to 4 and choked the lines until i got square ends. The lines were not a solid color so I added alpha levels and cranked the input white clear down to 0 which got rid of the gray. Now the layer can be used as a luminance track matte for a yellow layer.
    square end stripes…. wow! I’m so proud of myself.
  • Editing-jos
    February 17, 2006 at 1:11 am
    wasnt it possible to just use TEXT on a Path? You can animate that!
    You can use the minus for the line. In the ascii code are still more elements to use. Or special fonts with signs.
  • Noe Marti
    February 17, 2006 at 10:27 am
    Thank your for all Ideas. The “Minus” is the solution. That’s it ! Thank you for this great Idea,
    Text on Path and then use the minus – it’s that simple.
