Activity Forums Adobe After Effects Dot pattern animation – individual dot opacity control based on a gradient mask?
  • Dot pattern animation – individual dot opacity control based on a gradient mask?
    Posted by Gene Strocco on August 9, 2013 at 3:37 am
    Hi all,
    Hoping someone can help me with what I think should be a relatively straight forward animation project. I’m an intermediate AE user and somehow I think my brain is just freezing up.
    Here’s what I’m trying to do. I’ve got a dot pattern (please see reference pic) that I’d like to animate each individual dot’s opacity based on a mask animation. I don’t want to do just a gradient mask transition, because that’s too simple. I want to make each dot ‘pop’ on as whatever shape I make animates over it.
    A good example is when using a mask on CC Ball Action, which draws each ‘ball’ as you animate the mask over it. However, Ball Action doesn’t allow you to create an off-set row pattern like the one in my image, and I’d also like to see if the opacity can gradually fade in/out based on the feathering or the gradient/mask edge.
    So, in summary, please reference my image and imagine the wave gradient mask I created controlling the opacity of each individual dot. Hope someone out there can help me!
    G.
    Roland R. kahlenberg replied 13 years, 1 month ago 4 Members · 4 Replies
  • Mathew Fuller
    August 9, 2013 at 7:28 am
    See if this helps at all.
    https://m.videocopilot.net/tutorials/3d_ball_dispersion/
    Thats a mobile link from my phone. But basically its tutorial 103 “3D ball dispersion” on that site.
    You should be able to get a few ideas from this tutorial to get you going in the right direction.
    My Work:
    https://www.morecompletefx.com
  • Roland R. kahlenberg
    August 9, 2013 at 2:15 pm
    I’ve attached an AE Project File (CS6 and CC versions included) in a ZIP package.
    6384_particleplaygroundoffsetdots.zip
    The AEP uses two Particle Playground layers to create a grid of dots that are offset on the x-axis, on alternate rows. The dots are from a precomp and are used as a custom particle by the PP layers.
    Both PP layers are linked to a precomp (Opacity Map) which affects the opacity of the dots.
    By changing the Opacity Map, different outcomes are possible in the PP layers.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Erik Waluska
    August 10, 2013 at 6:31 pm
    Once again you’ve opened my eyes to the possibilities of Particle Playground. I can imagine a ton of potential uses for this effect alone. Thanks Roland!
    Erik Waluska
    EAWmedia
    August 14, 2013 at 3:35 am
    You may want to check out a tutorial I did a while back – https://library.creativecow.net/articles/kahlenberg_roland/shattering_world.php
    Cheers
    RoRK
