Activity Forums Adobe Encore DVD “Don’t Transcode” setting not available for DVD compliant MPV / M2V
  • “Don’t Transcode” setting not available for DVD compliant MPV / M2V
    Posted by Zoombots on June 30, 2005 at 5:30 am
    I bought a cheap MPEG2 capture card (MedioStream NEO) and can’t seem to import its MPEG video in Encore without having to re-trancode it..
    The MPEG2 files seem DVD compliant at 720×480 @ 29.97fps, I also tried demuxing and import the video footage as .mpv and .m2v – still no luck; the “Don’t Transcode” option is still grayed out. However, the demuxed .mpa audio DOES have the Dont Transcode option available.
    Anyone have any ideas? This capture card is not saving me any time!!!
    Francis
    Alex replied 21 years, 2 months ago 3 Members · 3 Replies
  • Roadkill
    June 30, 2005 at 11:19 am
    Francis,
    Could you inspect one of the MPEG files with Bitrate Viewer and post the data from the lower right (stream type, nom. bit rate, etc.) plus the value in the “peak” bit rate field?
  • Zoombots
    June 30, 2005 at 2:38 pm
    This is what BV analyzed:
    Num. of picture read: 2026
    Stream type: MPEG-2 MP@ML VBR
    Resolution: 720*480
    Aspect ratio: 4:3 Generic
    Framerate: 29.97
    Nom. bitrate: 8234000 Bit/Sec
    VBV buffer size: 112
    Constrained param. flag: No
    Chroma format: 4:2:0
    DCT precision: 8
    Pic. structure: Frame
    Field topfirst: No
    DCT type: Field
    Quantscale: Nonlinear
    Scan type: Alternate
    Frame type: Interlaced
    Notes:
  • Alex
    July 5, 2005 at 3:14 pm
    so what’s the final answer on the transcoding question.
    i have a canopus capture card , out put to mpg2, encore still transcodes the
    project.
