Activity Forums Adobe After Effects Expressions Don’t run every frame
  • Don’t run every frame
    Posted by Ad Narayan on May 2, 2019 at 3:32 am
    Hey guys,
    I’m wondering if there’s a way to create a random position, but then hold that random position, from when an even triggers until it ends.
    Essentially, my event is
    a = effect("Advanced Lightning")("Core Radius");
    When a is not equal to 0, I’d like my script to calculate (and most importantly hold on to) a new position.
    if (a != 0) {
    x = random(0, 3840);
    y= random(0,768);
    curPos = [x,y];
    However, the way this works is that for every frame a is not 0, I’m given a new random position.
    Is there a way to trigger this the first time a changes from 0 to another value. I thought maybe a do/while would work, but that’s timing out AE’s engine.
    Any help would be appreciated. Thanks heaps!
    Lead VFX and Motion Design at Tomorrowland NZ
    Filip Vandueren replied 7 years, 4 months ago 3 Members · 3 Replies
  • Tomas Bumbulevičius
    May 2, 2019 at 6:26 am
    Hey Ad, check this thread covered, might be helpful for your case to catch the difference: https://forums.creativecow.net/thread/227/40694
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
  • Ad Narayan
    May 2, 2019 at 7:02 am
    You just saved my butt. I knew about seedRandom but did not know about the “timeless” second argument! Thanks heaps 🙂
  • Filip Vandueren
    May 2, 2019 at 7:15 am
    seedRandom(index,true); // "index" could be any number; ",true" makes sure the _same_ random numbers are always generated.
    fd=thisComp.frameDuration;
    p=random([0,0], [3840,720]); // even if this is called every frame, it will always return the same random number
    // we have to loop through time and check how many times "a" has become 0
    // by generating a random number for each occurrence of a=0 but was not 0 one frame ago,
    // every subsequent random() call yields a different random number.
    for (t=0; t<=time; t+=fd) {
    if (a.valueAtTime(t)==0 && a.valueAtTime(t-fd)!=0) {
    p;
