Activity › Forums › Adobe After Effects › Don’t render layer
  • Don’t render layer
    Posted by Matt Larson on March 7, 2007 at 7:46 pm
    I’m creating video with an alpha layer to composite into FCP. I’ve got the base layer in FCP, but I am using the image in AE as a guide as well. When I render, I have to remember to “turn off” the background guide layer, so I can composite correctly in FCP. The problem is, I keep forgetting to turn off the guide layer and the re-rendering is killing me.
    Is there a way to set a background layer NOT TO RENDER, regardless of whether it is visible or not?
    Mylenium replied 19 years, 6 months ago 4 Members · 4 Replies
  • Kevin Camp
    March 7, 2007 at 8:02 pm
    select the layer that you are using as a guide in your comp. then go to the layer menu, select ‘guide layer.’ now, unless you’ve changed the ‘best settings’ in your render settings, it won’t render. if you click the render settings you can see the setting for guide layers (normally set to off).
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Filip Vandueren
    March 8, 2007 at 3:56 am
    I think this was introduced in AE7, so if you’re working with 6.0 or 6.5 you’re out of luck…
  • Filip Vandueren
  • Mylenium
    March 8, 2007 at 11:51 am
    Nope, AE 6.5 brought us this “revolutionary” feature. ;O)
    Mylenium
    [Pour Myl
