Activity › Forums › Avid Media Composer › dollar signs over clips?
  • Michael Phillips
    January 13, 2016 at 7:27 pm
    Can you post a screenshot?
    Michael
  • Ludmil Kazakov
    January 13, 2016 at 8:05 pm
    here it is
  • Shane Ross
    January 13, 2016 at 8:21 pm
    Those aren’t dollar signs…those are NEW graphic indicators that there’s something different about the clips. Before, all you’d get is a green dot, meaning “something about this clip is different.” now, Avid tells you WHAT about the clip is different. S means SPATIAL, meaning that the clips are a different size than the project. Say 4K clips in a 1080p project, or SD clips in an HD project.
    Shane
    Little Frog Post
  • Michael Phillips
    January 13, 2016 at 8:32 pm
    You can turn these off or on individually in timeline settings if you want under “show adapters.” To elaborate, you can see up to three indicators:
    1. C for color (A LUT has been applied to the source)
    2. S for spacial (source raster does not match project or has FrameFlex)
    3. T for temporal (frame rate does not match project rate)
    Michael
  • Ludmil Kazakov
    January 13, 2016 at 9:46 pm
    that makes sense.. thanks guys! yes this is 1080 footage in 2k project..
