Activity Forums Apple Motion Dollar Bill particle pile up
  • Dollar Bill particle pile up
    Posted by Top Manta on November 2, 2010 at 12:49 am
    I am attempting to simulate a person being covered in a pile of money that rains down for a music video.
    I´ve tryed doing this by layering various emitters with the edge collision behavior applied and offset to get the fallen particles stacking up, but the particles accumulate at the bottom of each emitter and reveal obvious horizontal lines in the stack.
    Does anyone know of a more elegant, organic looking way to create a particle pile up within Motion?
    Jimmylee Remillard replied 15 years, 9 months ago 4 Members · 3 Replies
  • Andy Neil
    November 2, 2010 at 5:51 pm
    I wouldn’t use an emitter. The particles in an emitter are either all moving or all stopped. You can’t have some stopped and some moving making your idea of falling like rain and then piling up impossible.
    Instead, I’d use a replicator. You can animate the replicator by using the Sequence replicator behavior to animate its position. Set the starting point of the animation off frame.
    Andy
    https://www.timesavertutorials.com
  • Sacha Thomas
    November 4, 2010 at 8:45 pm
    Stephen has a tutorial on confetti. Maybe that would point you in the right direction.
    here is the link:
    https://library.creativecow.net/articles/smith_stephen/particle_party.php
    Good luck
  • Jimmylee Remillard
    November 29, 2010 at 5:30 am
    I would just go to the premade partical emitters – select either fall leaves or feathers and change the image to a dollar bill.
    Yiu can also add another emitter that has a long life which will build up dollar bills from the floor to give the illusion that the falling leaves emitter is flooding your talent with cash flow.
