Activity Forums VEGAS Pro Dolby Rendering Question
  • Dolby Rendering Question
    Posted by Franz Vorenkamp on June 22, 2008 at 9:37 am
    Hey guys,
    I’m wanting to render a final project I’ve been working on- I’ve spent hors and hours mixing the audio very carefully into 5.1 surround…
    The question now is how do I render it?
    Common sense says that there should be an option under the default MPEG-2 format to put the audio into AC-3… However, I do not see this option in the sound settings. I definitely have the AC-3 plugin as I can render just an audio track as such. However, I see no video/audio combo that supports surround sound.
    Does anyone know what I’m missing?
    Thanks in advance!
    – Franz M. Vorenkamp
    Franz Vorenkamp replied 18 years, 3 months ago 2 Members · 4 Replies
  • Mike Kujbida
    June 22, 2008 at 11:25 am
    Franz, AC-3 is a separate render.
    Select “Dolby Digital AC-3” in the “Save as type:” dropdown box.
    After that, select “5.1 Surround DVD” in the “Template” dropdown box.
    Customize if necessary.
    BTW, do not trust DVD Architect for accurate 5.1 playback.
    Burn it to a DVD and check it on your sound system.
  • Franz Vorenkamp
    June 22, 2008 at 7:09 pm
    That’s what I was guessing… But if not DVD Architect, then which program should I author the final disc in?
  • Mike Kujbida
    June 23, 2008 at 12:17 am
    My apologies for the way I phrased my response.
    DVD Architect is an excellent authoring tool to use for this purpose.
    What I should have said was don’t trust the audio playback in DVD Architect for accurate 5.1 audio reproduction.
  • Franz Vorenkamp
    June 23, 2008 at 12:55 am
    Perfect. I feel much better now
