Activity Forums Adobe Encore DVD dolby encoding with encore
  • dolby encoding with encore
    Posted by Bodybuildingbs on August 3, 2005 at 4:52 am
    I have a project almost finished in premiere 6.5. Do I need to import the clips into audition to encode them and then back to premiere 6.5 or can I encode them in encore and will encore work with premiere 6.5. Please advise and thank you so much for taking your time on this forum.
    Kylesway replied 21 years, 1 month ago 4 Members · 4 Replies
  • Tim Kurkoski
    August 3, 2005 at 4:06 pm
    Jack- What is it exactly that you want to accomplish?
    Encore can take WAV files from either Premiere (any version) or Audition and encoded them appropriately for a DVD. It can encode them as PCM, MPEG-2, or Dolby. Stereo only; if you want surround you need a separate encoder.
  • Bodybuildingbs
    August 3, 2005 at 4:14 pm
    Am trying to prepare a DVD for a short for a film festival where it will be played in a theatre that has the 5:1 digital sound. Now obviously you have to tell the sound where to go so is that option available in encore?
  • Joe Bowden
    August 4, 2005 at 3:17 pm
    Encore only encodes to Dolby Digital 2.0 (stereo).
    If you want 5.1 sound, you’ll have to create and encode it to Dolby Surround in other applications. You can then import the Dolby Surround AC3 file into Encore and your DVD will feature surround sound.
  • Kylesway
    August 16, 2005 at 1:58 pm
    Hi all
    note that any 5.1 theatre should be perfectly happy when it
    gets just 2.0. Obviouisly it won’t be surround then, just
    ordinary stereo. But you should be able to play it back w/o
    problem.
    Hope this helps
    — Kyle
