Activity Forums Apple Final Cut Pro Legacy Dolby E for QT file output
  • Dolby E for QT file output
    Posted by Jeffrey Moorbeck on November 26, 2013 at 3:54 pm
    We received a program for air recently and it is file based. It is a QuickTime with a 5.1 surround mix. For air we need Dolby E encoding. I sent the audio to our ProTools person as they have a plug-in for the encoding and output four audio channels (Channels 1 & 2 stereo LR and Channels 3 & 4 are the Dolby E data tracks). I added the audio to the video on a timeline and output the QT to drop into our air server.
    However, the Dolby E data tracks are not recognized so we can’t air the surround mix. Is their a way in FCP to output as a QT that will preserve the Dolby E data for air?
    Jeffrey Moorbeck
    Senior Editor
    Milwaukee Public Television
    Mark Spano replied 12 years, 9 months ago 2 Members · 4 Replies
  • Mark Spano
    November 27, 2013 at 3:27 pm
    Only thing I can think of is perhaps your timeline is set for 16-bit audio. The Dolby E stream is 20-bit, so only a 24-bit timeline would preserve the stream intact.
  • Jeffrey Moorbeck
    November 27, 2013 at 4:33 pm
    Thanks Mark, I will give that a try, and yes it was set for 16 bit.
    Jeffrey Moorbeck
    Senior Editor
  • Jeffrey Moorbeck
    November 27, 2013 at 7:55 pm
    That did the trick! Changed the FCP audio settings to 24-bit and problem solved.
    Jeffrey Moorbeck
    Senior Editor
  • Mark Spano
    November 27, 2013 at 8:18 pm
    Ah – glad it was an easy fix!
