Activity › Forums › Apple Final Cut Pro Legacy › Dolby 5.1 Through SDI
Posted by Edit.one on March 9, 2007 at 5:48 pmis there any difference in out putting the Dolby 5.1 through HD SDI to a HDCAM than the AIFF full mix tracks ?
is the Dolby 5.1 a different file format ?we are using FCP 5 & Kona LHe card
thank you in advance for the advise
Best,
edit.oneJuan Salvo replied 19 years, 6 months ago 4 Members · 7 Replies -
Aaron Neitz
March 9, 2007 at 6:28 pmA real Dolby 5.1 file is an encoded stream that contains all 6 channels (typically a Dolby E mix will get laid down to channels 3/4 on an HDCAM… and it contains all the metadata and the audio data for the 6 channels therein).
If you send 6 channels straight to deck from AIFF’s, that’s all they are – 6 discreet channels without the Dolby matering, metadata, and encoding.
Edit.one
March 9, 2007 at 7:46 pmThank you,
just to be precise you’re saying that if I place on FCP timeline the ‘Dolby 5.1 encoded stream’ (Dolby E mix to channels 3/4 ) it will go through the HD SDI to tape or do I need a special way to put them in HDCAM?.
can I hear them from my audio speakers in case to monitor that they are there or if everything is right?Best,
edit.one -
Aaron Neitz
March 9, 2007 at 8:34 pmDolby E is an encoding method that gives you a 2 channel PCM stream which contains 6 or 8 channels of audio (16 or 20 bit depth). If you tried to listen to it, there’d be nothing… your AES to analog decoder would be stimied – you’d have to buy a purpose built Dolby E to analog decoder.
You can transport this stream over AES or SDI as long as it remains BIT for BIT accurate. So, in theory, if you digitized a Dolby E track over SDI, you could lay it off to another tape.
BUT: we never do this in our studio. We finish everything on D5 with 8 channels of regular audio and let Dolby labs or the network or the mix house deal withe the encoding. so really all my knowledge is academic and not hands on. I can’t guarantee FCP or the Kona won’t swap some bit information or do some sample rate conversion to the Dolby PCM stream. Good question for Aja tech support!
Matt Galuszewski
March 9, 2007 at 10:58 pmIf you are intending to capture the Dolby E data stream, do some cut only editing and then output back to tape then I can tell you the following.
The AES inputs on the Kona 3 card corrupt the DOLBY E data stream whilst the embedded embedded audio does not.
Regards
Edit.one
March 9, 2007 at 11:16 pmHow about to take the Dolby PCM stream from audio studio and without changing it to place in audio tracks of the secuence I mean just matching the start and the end point and lay on tape together with video through SDI out. will that corrupt the ‘bit by bit’ transfer of signal ?
I guess the best advise yet is to let the audio people to do the 5.1 layout or I have to take the challenge if budget will allow.I’ll reach AJA and If I learn anything I’ll post it.
thank you for the real professional help
edit.one
Aaron Neitz
March 9, 2007 at 11:50 pmThe slightest change in the audio stream will corrupt it. So if you’re HDCAM wasn’t at unity and added +1 DB to audio tracks – I think that’ll ruin it. So just give the final master tape to the audio house for final layoff. good luck
Juan Salvo
March 15, 2007 at 3:39 pmActually just capturing it into FCP, resamples the audio… so the Dolby-E data is lost…. it will no longer be recognized by a Dolby decoder… so the short answer is no, you can’t do this.
