Activity Forums Apple Final Cut Pro Legacy Doing an Mpeg 1 in compressor with other sizes than 320×240.
  • Doing an Mpeg 1 in compressor with other sizes than 320×240.
    Posted by Josh Weiss on January 18, 2007 at 11:07 pm
    For some reason it seems as if compressor won’t let you changed the size of an mpeg1 to anything else. Is there a way to get around this. We need to deliver a PAL 720 x 486 mpg1. We can do it in AE or other programs, but why not compressor? Any ideas would be appreciated.
    Rafael Amador replied 19 years, 8 months ago 3 Members · 3 Replies
  • Rafael Amador
    January 19, 2007 at 3:01 am
    I think that MPG1 standard admits only one size: 320×240 and a bit-rate. But I think with ff-mpgx you can change the setups as you need it.
    Salud,
    rafael
  • Rennie Klymyk
    January 19, 2007 at 8:57 am
    [rafalaos] “I think that MPG1 standard admits only one size: 320×240 and a bit-rate.”
    Actually you can vary the structure almost as much as mpeg2. My mediapress card will do 720X480 down to 48X32 and it does 1×1; 4:3 or 16X9 aspect ratio. The format was in wide use predominantly in Asia 5 or 6 years ago for producing video cd’s but I don’t think it sees much use anymore. At that time blank dvd-r media was costing about $20.00 per disc and there was a big error margin. With the progress made in dvd software and the low cost of dvd discs it’s odd anyone is requesting it although you can email the files pretty easily. You could put a 90 min. movie at near vhs quality on a 750mb cd with it.
    If your clients are really stuck on this format try googling mpeg 1 encoder, there should be a ton of freeware for it. Apple has never supported it from early on but instead pushed their own motion jpeg A and motion jpeg B (equally useless by todays standards).
  • Rafael Amador
    January 19, 2007 at 12:58 pm
    Thanks for the information Rennie. You are really up-dated.
    I came to live to Asia few years ago and I found the VCDs for the first time. And as you say Apple never helped with that. I had to use a bunch of funny frewaare that some times worked (MJPGTools, MissingMPGTools, ffmgx..).
    At the momment they are still in use mostly for the Karaoke, but people start to buy DVD players.
    Salud,
    Rafael
