Activity › Forums › DaVinci Resolve › Does v8 support multiple redrockets for epic 5k Hdrx
  • Does v8 support multiple redrockets for epic 5k Hdrx
    Posted by Paul Mitchell on July 15, 2011 at 4:16 pm
    Hello
    For working with epic 5k Hdrx combining A and X tracks does resolve v8 support multiple redrockets in an external xpander box?
    Danny Scotting replied 15 years, 2 months ago 2 Members · 1 Reply
  • Danny Scotting
    July 19, 2011 at 12:48 am
    Hi Paul, the answer is yes. Here is a section from the V8 manual that mentions it.
    A Note About RED HDR Media and Performance
    Since RED HDR media records two complete streams of image data, DaVinci Resolve must simultaneously decode two separate tracks whenever you add a second Source bar. If you don’t add the second Source bar, only the first stream is decoded.
    Because of this, whether you’re relying on your computer’s CPU to decode RED media, or you’re using a single RED ROCKET card, you’ll get half the performance when using the highlight stream of an HDR clip.
    To improve performance, you can set any RED HDR clip’s Render Cache Mode to “User” by choosing Session > Render Cache Mode, pressing Option-R, or pressing the CACHE MODE button on the T-bar panel of your control surface repeatedly until you toggle to User mode. DaVinci Resolve renders all cached clips in the background, so the next time you play a cached clip, it will play at full speed.
    If you regularly use RED HDR media, two RED ROCKET cards are recommended for optimal decoding performance.
    Danny Scotting – Senior Colourist
    Post Op Group Sydney
    https://postopgroup.com.au/site/?page_id=1052
