Activity Forums Blackmagic Design Does the analog to SDI mini-converter upconvert?
  • Does the analog to SDI mini-converter upconvert?
    Posted by Joel Bialek on November 21, 2011 at 9:32 pm
    Sorry if this has been answered before, but I’m trying to engineer a new video system and am looking at BMD to fit the bill. I’m planning on using an ATEM 1M/E, but I want to be able to get an SD DVD player into the switcher while still maintaining a 1080i program output.
    Would the Analog to SDI converter do this for me? Or do I need to use a combination of the Analog and the Up/Down/Cross converter?
    Thanks ahead of time.
    Joel
    Evan Vickers replied 14 years, 1 month ago 5 Members · 5 Replies
  • Bob Zelin
    November 22, 2011 at 2:52 am
    you need both. Analog to SDI to convert to SDI 525 NTSC, and the “up converter” to go from SD-SDI to HD-SDI.
    Bob Zelin
  • Joel Bialek
    November 22, 2011 at 2:28 pm
    Thanks Bob. I appreciate it.
  • Marc Colemont
    November 30, 2011 at 7:26 pm
    What about delay when using the upconvertor?
  • Robert Dewerff
    December 7, 2011 at 12:05 am
    I use both inline often, when converting from a DVD-player to HD-SDI. SDI monitor patched at first conversion, and at second up convert. I have not noticed a delay… So I guess it would be better to say the delay, if any, is not noticeable.
    In the world of individual frames, this answer may not be acceptable.
    Bob D
    America One Networks
  • Evan Vickers
    August 16, 2012 at 6:25 pm
    Wouldn’t it be easier to use the Component input of the ATEM 1/ME?
    You should just need a DVD player cable of upscaling to the same format you run your system.
