Activity › Forums › AJA Video Systems › Does Size Matter?
  • Does Size Matter?
    Posted by 808marcus on November 17, 2006 at 1:16 am
    Just switched over from Media 100 to FCP on a new 2.66 Mac Pro. Setup with a new KONA LHe which digitizes from a Sony BETA SP PVW-2800. I am capturing and creating sequences of 8-bit uncompressed SD which is stored on an internal RAID 0 of 1.5 TB.
    I notice that the AJA KONA captures at 720×486, but my Sony Camera, DXC-50WS with PVV-3 BETA SP, is 640×480. I am producing broadcast commercials and some corporate videos, and know that on a consumer TV they won’t see the edges, but is that normal. Or am I missing a capture setting for 640×480 with the AJA KONA LHe?
    Thanks for the input in advance.
    Aloha,
    Marcus Reimel
    Jeremy Garchow replied 19 years, 10 months ago 4 Members · 3 Replies
  • Walter Biscardi
    November 17, 2006 at 4:06 pm
    Media 100 never worked in the true broadcast sizing. 640×480 is really a computer standard that Media 100 made work in outputting to tape. I used M100 for about 6 years and it was a great system.
    True NTSC broadcast is 720×486 which is probably what your camera should really be shooting. You thought it was 640×480 because that’s what Media 100 captured at. Use the Uncompressed 8bit SD Kona setting and you’re good to go.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Gary Adcock
    November 17, 2006 at 5:05 pm
    [808Marcus] “I notice that the AJA KONA captures at 720×486, but my Sony Camera, DXC-50WS with PVV-3 BETA SP, is 640×480.”
    the difference is called over-scan and it can be used to hold some ancillary data.
    on a consumer set the over-scan is cropped off on delivery, so the final image is 640×480
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Jeremy Garchow
    November 17, 2006 at 5:49 pm
    Also, 640×480 is a square pixel set while 720×486 in non square pixel which also might be sort of confusing to you when making the switch. It confused me the first time I did a project on FCP3 after editing on M100. If you use photoshop at all (which is a square pixel environment) you will have to conform your images to non square by first designed at square pixel then squeezing. After Effects handles the aspect ratio conversion very well for you, Photoshop does not. There’s a section in the FCP manual that you should read about creating graphics in photoshop.
    Hope this helps.
    Jeremy
