Activity Forums Apple Final Cut Pro Legacy does shure x2u work with fcp
  • does shure x2u work with fcp
    Posted by Jurriaan Van der kamp on June 7, 2011 at 10:18 am
    Hi
    i was wondering if a shure x2u work with fcp’s vo tool.
    That instead of the internal mike you now can use a xlr condenser mike.
    I now use the digidisighn mbox and it works fine with leopard but to let it work with snowleopard
    seems to be a hassle.
    So does the shure x2u work with fcp does it mirror th quality you get from say my mbox?
    thanx. jur
    Andrew Rendell replied 15 years, 3 months ago 3 Members · 2 Replies
  • André Engelhardt
    June 7, 2011 at 7:03 pm
    Hi Jurriaan,
    the Shure X2u should work just fine with Snow Leopard! In the VO tool’s source drop-down menu just select the “Shure Digital” input and you’re all set.
    As far as quality is concerned I doubt you will hear much of a difference for voiceovers, so you should be fine.
    Good luck!
    André
    Sound, Music, Film, Photo
    http://www.andreengelhardt.net
  • Andrew Rendell
    June 8, 2011 at 3:57 pm
    I’ve got a Lexicon Alpha and a Samson Go Mic and both of those worked straight away without a hitch (FCP7, Snow Leopard), so I’d be surprised if there was a problem with the Shure.
