Activity Forums Apple Final Cut Pro Legacy does “self-contained” recompress?
  • does “self-contained” recompress?
    Posted by Aidan Fraser on February 21, 2007 at 8:16 am
    If I trim a DV clip in Quicktime Pro and save as with “make self-contained” selected will it recompress the movie or make an exact copy of the trimmed frames?
    Will it cause problems with timecode in FCP?
    -Aidan
    Rafael Amador replied 19 years, 7 months ago 3 Members · 4 Replies
  • Nick Meyers
    February 21, 2007 at 11:16 am
    i’m not sure.
    i do know that if you do the same thing in FCP all is well, quality-wise, and TC-wise.
    you can also be a bit more accurate with your in/out points.
    nick
  • Rafael Amador
    February 21, 2007 at 12:41 pm
    If the setting of your time-line is exactly the same that your footage, unless you check the “recompress all frames”, when exporting, only the clips that you apply a filter or chage any parametter in the motion tab are recompressed.
    About the TC: when you export a clip in FC a new TC is generated. If you want that your new clip start with a certain TC, you can set it in the prefferences.
    Cheers,
    rafael
  • Nick Meyers
    February 21, 2007 at 12:49 pm
    raf, you’re talking about exporting SEQUENCES.
    they take on the timecode of the sequence.
    if you export a CLIP from FCP as a QuickTime Movie it retains the clip;s original TC
    nick
  • Rafael Amador
    February 21, 2007 at 1:31 pm
    Sorry Nick, you are right. When you trim a clip in the brownser window and export its keep the original TC. I was thinking about exporting something from the time-line.
    Cheers,
    rafael
