Activity › Forums › VEGAS Pro › Does re-rendering cause loss of quality?
  • Does re-rendering cause loss of quality?
    Posted by Robert61 on June 15, 2007 at 12:27 am
    I have video in Vegas that I want to edit in pieces.
    If I render each piece, and then piece together later with nothing more than butting the pieces together, or perhaps adding a crossfade between sceens, will the video portions (excluding any crossfades between sceens) contain the same quality? Or is each frame re-rendered, and therefore lossy compressed again? Or does it just pass frames with no changes as they were before?
    Gary Kleiner replied 19 years, 3 months ago 3 Members · 2 Replies
  • Mike Kujbida
    June 15, 2007 at 12:01 pm
    Only the portions that have FX applied to them will be re-rendered.
    The codec in Vegas is very good though so the quality loss will be minimal.
    You could use nested vegs (Vegas 6 and newer) and avoid this compression completely.
  • Gary Kleiner
    June 15, 2007 at 4:14 pm
    … assuming the format is DV.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
