Activity › Forums › AJA Video Systems › DOES RADEON X800 XT HAVE ADC CONNECTOR TOO?
  • Christopher Tay
    June 25, 2005 at 2:55 am
    Yes it has an ADC and a DVI connector.
    -chrispy
  • Scott Thomas
    June 25, 2005 at 8:33 am
    If you desire to run a dual monitor setup, an ADC to DVI adaptor if fairly inexpensive and simple. ADC contains all of the signals that are present on a DVI connection, so the adaptor is no more complicated than a gender changer. I just bought one for my Radeon 9800.
  • Gary Adcock
    June 25, 2005 at 10:38 am
    The x800 does have both an ADC and DVI connectors,
    Note the Mac version of the board is different from the PC version that is commonly found at Comp Usa or Best Buy.
    It does drive the 30 in Cinema Display and can accelerate GPU based applications such as Motion OR SiliconColor.
    gary adcock
    Studio37
    HD and Film Consultation
  • Jerry Hofmann
    June 25, 2005 at 8:18 pm
    If you don’t need two 30″ CD’s it’s the way to go I think… fastest Mac card out there. https://www.barefeats.com reports it to be the fastest card. Plus, it doesn’t take up two slots like the rest, which would be in my case, mandatory.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jim Blokland
    June 27, 2005 at 1:58 pm
    I’m trying to run two older ADC displays off this card. I already have one ADC/DVI adaptor but I was hoping to avoid having to get another. Anyone running the X800 with and ADC monitor off the ADC connector? Is it receiving power/USB/signal as it’s supposed to?
    Thanks in advance.
    Best, JIM.
  • Walter Biscardi
    June 27, 2005 at 2:35 pm
    [Jim Blokland] “Anyone running the X800 with and ADC monitor off the ADC connector? Is it receiving power/USB/signal as it’s supposed to?”
    Yep, I have two ADC monitors running off the card. I have a 23″ Cinema Display using the ADC-DVI Adapter from Apple and I have my 17″ Studio display running straight into the ADC port on the card. USB ports operate correctly and the monitor gets powered up correctly as well.
    The only thing that happens from time to time is the power light will stay on the 17″ display even when I power down. Doesn’t happen all the time, but it does happen occassionaly.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Jim Blokland
    June 27, 2005 at 4:45 pm
    Walter:
    Thanks so much for the confirmation.
    Best, JIM.
    OSX.4.1
    Dual 2.7 G5
    3.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
  • Nigel Thompson
    June 27, 2005 at 10:27 pm
    I saw on Barefeats that the x800 was faster at everything but Motion, what do you guys think about that
