Activity › Forums › Adobe Premiere Pro › Does Premiere support Full Screen Video playback?
Posted by Jacob Webber on July 3, 2009 at 11:05 amHi,
Does Premiere support Full Screen Video playback? If so, can it do this on a secondary monitor?
I need to run broadcast graphics from my pc which will be going through a scan converter.
Any help would be really appreciated
Cheers
Jacob
Chuck Pietro replied 17 years, 1 month ago 9 Members · 9 Replies -
Jeff Brown
July 3, 2009 at 1:55 pmWouldn’t it be easier to buy a SDI card and skip the scan converter?
-jeff
Vince Becquiot
July 3, 2009 at 3:07 pmIt will support full screen playback as long as you have 2 cards, or a good dual head. DVI or VGA.
It’s not a perfect solution as you may have some scaling issues depending on the footage. All you need to do is select the second screen as an “extended monitor” and select it in the playback settings.
You will also need a beefy GFX card on the second monitor side for smooth HQ playback, plan on $250.00 and up in the ATI/Nvidia series.
Of course , as Jeff said, SDI is the way to go, but it certainly is very expensive.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Tim Kolb
July 3, 2009 at 4:56 pmOr an HDMI card…those aren’t as expensive.
TimK,
Director, Consultant
Kolb Productions, -
Brian Louis
July 3, 2009 at 7:25 pmYou might want to look at Matrox MX02 mini, there are versions for either laptop or desktop or with addition of a extra card-both, it will I/O HD/SD thru HDMI, Component, Y/C or Composite
Tim Kolb
July 4, 2009 at 3:35 amAJA makes the I/O Express as well…it’s a solid option as well.
TimK,
Kolb Productions, -
George Socka
July 6, 2009 at 11:47 pmplug in a DV ( assuming DV project) thing – camera, recorder, pyro, whatever. plug its video out to whatever you are recording into. No scan converter.
George Socka
BeachDigital
http://www.beachdigital.com -
Arc Nevada
July 17, 2009 at 6:40 pmhttps://www.youtube.com/watch?v=mhp4NsJFRpU
I agree with what has been said already. You can use the HDMI or even S-Video out of the graphics card. I still use a DV converter even when editing HD so that I can make use of two VGA/computer monitors while editing. The DV converter works decent with HD for CC, transitions and other things but some motion graphics will be a tad bit jerky because you are restricted to 720X480 resolution. There is a reason to get a Decklink card if you want to run dual computer monitors along side of the NTSC monitor.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Chuck Pietro
July 28, 2009 at 2:23 pmThis is just what I have been trying to do; show the monitor panel in full screen. I have a Windows XP laptop and would like to send the full screen monitor panel in Premiere to a projector so the hockey coach can review the game with the kids. I’m new to all the hardware mentioned in this thread but could anyone tell me “in layman’s terms” what hardware I would need to add to my laptop to make this happen. Right now the laptop has a VGA out that I use to connect to the “VGA in” on the projector. The projector also has “composite in”. All the footage is catured from standard resolution DV tape. Thanks very much for your help.
