Activity Forums Adobe Premiere Pro Does Premiere Pro 2 support H264
  • Does Premiere Pro 2 support H264
    Posted by Ross Bradshaw on July 30, 2009 at 1:59 pm
    Hello
    I was just wondering if I can export to H 264 from a SD Pal project using Prem Pro 2? I normally use CS3 & 4 but i have been asked to do a mate a favor and I don’t have much time to investigate properly. If anybody out has encountered this issue it would be very much appreciated.
    Thank you
    Ross Bradshaw replied 17 years, 1 month ago 2 Members · 2 Replies
  • Brian Louis
    July 30, 2009 at 6:00 pm
    If you have a late version of QT there should be a H264 codec under the codec selector under QT option in the medea encoder, how it will work I don’t know
  • Ross Bradshaw
    July 31, 2009 at 9:27 am
    Cheers Brian I’ll dp a quick update on my quicktime and hopefully that will sort it out.
