Activity › Forums › Adobe Premiere Pro › Does Premiere CS3 use multiple CPUs for export?
  • Does Premiere CS3 use multiple CPUs for export?
    Posted by Max Phillips on August 1, 2008 at 3:50 pm
    As the title says, does Premiere use multiple CPUs? My boss is concerned that upgrading from a 3.0 ghz Pentium 4 to a Quad Core or a Dual Quad Core will not increase export time very much. I’ve been trying to get him to upgrade the computer for a while now, but some guy tells him that Premiere doesn’t use multiple CPUs, where I’ve read some different things on the Internet. Is there a definitive answer?
    Vince Becquiot replied 18 years, 2 months ago 3 Members · 2 Replies
  • Jon Barrie
    August 2, 2008 at 1:03 am
    the term being used is what’s causing the problem. CPU is not the same as Core. 1 x CPU can have multiple Cores. C2Quad example.
    You will bet a huge render and export + pre-render (red) Quality playback. CPU’s would imply it renders over several computers like in 3D rendering… that is not supported in PPro.
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Vince Becquiot
    August 2, 2008 at 1:17 am
    Basicaly, yes. If you run a dual Quad, it will use all Cores on both CPUs.
    Vince
