Activity › Forums › Adobe Premiere Pro › Does PPro 1.5 have plugin support for HDV footage?
  • Steven L. gotz
    May 18, 2007 at 7:33 pm
    Premiere Pro 1.5 has a free upgrade to 1.5.1.
    Encore 1.5 does not support HDV and After Effects should be OK, I don’t remember.
    You really ought to consider using the Adobe CS3 products coming out in the next month or two.
    Steven
    https://www.stevengotz.com
  • Darren Edwards
    May 22, 2007 at 1:37 pm
    The current selection of HDV plugins for ver.1.5.1 are
    quite an eclectic affair really (all available from Adobe),
    although quite unsurprisingly so considering that 2.0’s been
    out for quite a while. I’m reliable informed that 1.5.1
    will ingest Sony Z1/Z1e HDV material – which is, I suppose,
    one of the more popular HDV cameras out there.
    You should also consider Cineform’s HDV compression progs
    for PPro too:
    https://www.cineform.com/products/Aspect-Prospect.htm
    For what it’s worth, I think PPro 1.5 will remain my favourite
    SD NLE for time immemorial, so it’s quite painful to watch
    PPro lag so far behind in HD production vis-a-vis Final Cut/
    ProRes, etc.
    D.
    myspace.com/xgfmedia
