Activity Forums Apple Final Cut Pro Legacy Does my system need beefing up?
  • Does my system need beefing up?
    Posted by Shannon Bedford on December 14, 2010 at 9:00 am
    Firstly, I’m an editor not an I.T. guru so my apologies if I’m lacking knowledge about my own system. I’m learning!
    I have a Quad-core with 6 gig of Ram and AJA Kona LHe card. I’m wondering if my system is in need of more Ram or anything else.
    Up until now I have edited DV and HDV without problem. What has given me issues is graphics, photos, motion templates. When using HD templates or large photos, the system slows to the point that every mouse click takes about a minute to process. Final Cut frequently drops out altogether when this happens.
    A restart of Final Cut fixes the problem for a minute or two. Rendering does not make any difference.
    Is there a way to solve this problem? We are looking to upgrade our camer, is my system going to be able to cope with HD formats?
    If I need an upgrade, please advise me what I should be looking for.
    Thanks heaps.
    S Bedford, Western Australia
    Shannon Bedford replied 15 years, 9 months ago 2 Members · 7 Replies
  • 7 Replies
  • Thomas Morter-laing
    December 14, 2010 at 10:49 am
    What software versions? What operating system? What speed of quad core? What computer (eg iMac etc)?
    Tom Morter-Laing
    Freelance Editor
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
  • Shannon Bedford
    December 15, 2010 at 4:51 am
    Final Cut Pro 6.0.6
    Mac OSX 10.5.8
    Processor: 2 x 2.8 GHz Quad-core Intel Xeon
    Memory: 6GM 800 MHz DDR2 FB-DIMM
    did I miss anything?
  • Shannon Bedford
    December 21, 2010 at 4:15 am
    Hi Thomas, no one has given me any help with my query “Does my system need beefing up?”. Maybe everyone is taking Christmas holidays. Are you able to help me with this?
    I have added the info you asked for.
    Thanks heaps
    December 21, 2010 at 10:05 pm
    A few things that might help:
    Get on up to snow leopard, it’s a 64bit os which will use your computer more efficiently and help.
    Upgrade to FCP7, it’s not 64bit yet but it removed a lot of glitches and out of memory issues.
    The difficulty you may have is that the FCS can theoretically only use 4Gb Ram, and the type of Ram you have is a little slower than newer machines. At the moment though, cramming your mac with Ram will help a little, but you won’t notice vast improvements to things like rendering and whathaveyou; that’s more about your processor, which seems fine (again with snow leopard for added performance).
    We’re all hopeful for FCP 64 bit around feb which will help too!!
    Tom Morter-Laing
    Freelance Editor
  • Shannon Bedford
    December 22, 2010 at 4:10 am
    Thanks Thomas, I’m new to mac so I’ve had a bit of a look on-line but still a couple of questions I hope you can help with.
    If I move from OS X 10.5.8 to Snow Leopard, is it a simple upgrade or do I purchase the full price snow leopard software?
    If so, is changing the operating system pretty straightforward or would I need to do some backing up of settings etc?
    You mentioned the possibility of 64 bit around Feb. If I upgrade to FCP 7 now, will the 64 bit change be a simple free update? Or should I wait until Feb to upgrade to 7?
    cheers
    December 22, 2010 at 8:33 am
    The snow leopard upgrade you need is just the standard one (it’s 25 pounds here). You only need the “full” box set when upgrading from tiger (10.4), although the snow leopard disc is actually the same anyway, it’s actually to do with licence agreements (that’s something they don’t tell you lol). You don’t have to back up, it’s very straight forward it will just install and keep your mac as you left it, just with new snowy goodness. However it’s always worth backing up JUST in case something goes wrong. You should backup everything anyway, we had a hard drive specialist in the other day who said “the only thing you know for certain with a hard drive is that it will fail at some point”.
    Upgrading to FCP is a tricky one; I can’t remember if you can do upgrades past a version (eg FCP 6 to 8) for the price of an upgrade disc or if you have to get the full version. If you need the full version youre better off getting the 7 upgrade disc so when 8 comes out you don’t spend as much- it would still probably work out cheaper that way believe it or not. To answer your question, FCP8 in feb is only rumpled and hearsay, and no one knows anything certain at all except people high in apple, but Id put money on it being another expensive upgrade- no way will it be a “free upgrade”, especially if it’s rewritten in 64bit.
    Tom Morter-Laing
    Freelance Editor
  • Shannon Bedford
    December 23, 2010 at 1:23 am
    Thanks Thomas you’ve been a fantastic help so I will follow your advice to the letter.
    I particularly like what you said about Snow Leopard bringing “new snowy goodness”, something you seem to have so much of in the UK at the moment, but something that would be quite a novelty over here -the forecast is for 38 degrees Celcius Christmas day.
    Sending warm vibes your way.. merry Christmas!
