Activity › Forums › Apple Motion › Does Motion have an equivalent to AE’s Motion Tile effect?
Posted by Phil Williams on January 5, 2010 at 8:49 pmIs there any way of automatically repeating a texture in Motion a la AE’s Motion Tile effect? I want to try and achieve the effect of an “infinite” background texture that I can move across in any direction for any distance.
Phil Williams replied 16 years, 8 months ago 2 Members · 4 Replies -
Mark Spencer
January 5, 2010 at 8:54 pmTry replicating your tile into a rectangle pattern and you can use the offset parameter to shift the pattern
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Phil Williams
January 8, 2010 at 8:08 amThanks for that, Mark. It should have been obvious, but I guess sometimes it’s easy to miss the obvious!
On a related note, I’d be grateful if you could give me your insight on the following:
I want to emulate the sort of style you see quite a lot these days, where an animation begins, and then moves off the edge of the frame. The camera then moves to “catch up” with it, typically using a motion-blurred whip-pan effect. Or maybe the camera will leave the animation to zoom off to reveal a different part of the background, and the animation will then “catch up” with the camera. The sense you get is of the camera moving and the animation happening over a very very large background.
Am I right in thinking that the best workflow for this sort of project – especially if your background is made up of lots of different textures and still images rather than using a single seamless texture – is first to use something like Photoshop to create the background as one very large graphic image (say, 2-3x bigger than the resolution of the project) to allow plenty of room for dramatic camera moves over it? Or is there a more RAM-efficient way?
Mark Spencer
January 8, 2010 at 4:01 pmYou won’t be able to use textures larger than the limit of your graphics card – 2K, 4K, or 8K depending on the card. An alternative is to put a smaller graphic in a 2D group, which won’t be affected by the camera, or to set the background to a specific color.
Mark Spencer
Phil Williams
January 8, 2010 at 9:31 pmI’m only working in SD at the moment, so 2K would be big enough for me. I hear what you’re saying about the 2D group or the solid background colour, but I want to achieve the effect of the TV frame being a window onto a sort of photocollagey/scrapbooky background that we can’t see all at once.
